The first time the ARC Queen drops into an event in Arc Raiders, it doesn't feel like a "boss" so much as a problem your whole squad has to solve right now, and plenty of teams end up burning through ammo, heals, and nerves like they're spending ARC Raiders Coins on impulse. You'll hear the impacts before you really see her, and that's usually your warning to stop playing like it's a normal loot run. If you're not already calling lanes, marking safe ground, and deciding who's baiting what, she'll punish the first bit of hesitation.
Mortars and bad habits
Her mortar pattern is what catches most people. It isn't just splash damage; it's denial. The ground stays hot, so the "I'll just sit behind this rock" plan falls apart fast. The trick is to keep moving with purpose. Short sprints, quick stops, then move again. If you're always drifting in the same direction, she'll walk the shots onto you. Rotate your path, use small bits of cover, and don't stack on a teammate unless you like sharing a crater.
The beam and the panic spiral
Then comes the beam. It tracks, it chews health, and it makes people do dumb stuff. You'll see someone run in a straight line, then they clip a ledge, then it's over. What works better is breaking her line of sight and changing elevation when you can. A small ridge, a broken wall, a dip in the ground—anything that forces the beam to re-acquire. If you've got one player dedicated to pulling the beam away, the rest can actually shoot weak points instead of playing tag with death.
EMP windows and the slam
The EMP pulse is where the fight feels unfair, because your toys go dark. Shields drop, gadgets go quiet, and suddenly it's just aim, positioning, and timing. Don't rush her in that moment. That's when the slam comes out and wipes anyone who got greedy. Watch her body language: when she squares up and loads the motion, you back off. Call it early, even if you're not sure. Better to lose a few seconds of damage than lose a player and the whole rhythm of the fight.
Loot discipline after the kill
When she finally goes down, the real danger isn't her—it's the mess you're standing in. People sprint in to vacuum loot and forget the basics. Set a quick order: first, clear the immediate area; second, grab the high-value crafting pieces; third, get moving. ARC Alloys and Advanced Powercells are the bread and butter, but the Queen Reactor is the one everyone's quietly hoping for. If you're planning upgrades like movement modules or faster firing builds, scoop the cores and accelerators, then rotate out while your squad's still intact, because that's how a clean run turns into one you'd actually repeat, even if you're also thinking about ARC Raiders Coins buy in RSVSR for the next loadout tweak.
This difference provides consumers with diverse choices and also spurs product innovation among domestic manufacturers. In recent years, some Japanese manufacturers have begun incorporating traditional craft elements into chubby sex doll designs, creating product lines with cultural characteristics.
